Aqua Klean Systems, a leading provider of advanced PCB cleaning equipment, today announced that Amptech, Inc. has purchased a T-8 Chemistry Cleaner, T-12 Water Soluble Cleaner, and a Closed-Loop DI Recirculating System. Amptech is headquartered in Manistee, MI with plant operations in Michigan and Pennsylvania.
An AS9100:2009C & ISO 9001:2008 registered company, Amptech has been a leader in electronic assembly manufacturing since 1980. The company specializes in customer support from the beginning concepts of an idea to material procurement, circuit board assembly, wire harness build, housing/box assembly, testing to packaging and shipment to the customer.
Amptech’s new T-8 Chemistry Cleaner enables the company to efficiently clean RMA, no-clean and water soluble (OA) fluxes. The T-8 integrates a 15 horsepower wash pump with a combination of flooding and high-pressure wash for optimum impingement cleaning of PCBs. The dynamic air blow-off design allows for a water free zero-discharge chemical isolation.
Amptech also ordered a Typhoon T-12 Water Soluble Cleaner with a 24" wide belt, the industry's safest smart heater, quick adjustable pressure valves, easy to access front valves and innovative touchscreen software interface. Equipped with a 15 HP wash and rinse pump, and two 15 HP turbine blowers, the Typhoon T12's performance is unmatched.
The new DI Recirculating System will provide Amptech with cost savings and drastically reduce its water consumption. Aqua Klean DI Recirculating Systems are built with quality and durability in mind here in the USA. Every unit is quality tested in the Aqua Klean facility to ensure full and proper operation in the field. Only high-quality filters, pumps, valves, and electrical components are assembled into these units.
Amptech strives to meet its customers’ needs by providing quality services and products. For more information about Amptech, visit www.amptechinc.com. For more information about Aqua Klean Systems and the company’s wide variety of products, please visit www.aquaklean.com.
