Gen3 Systems to Exhibit with Stannol at productronica
Nov 08, 2013
CM11+ Contaminometer Cleanliness Tester
Gen3 Systems Limited, a specialist manufacturer of test and measurement equipment, announces that it will exhibit with its distributor, Stannol, in Hall A4, Stand 470 at the productronica International Trade Fair, scheduled to take place November 12 - 15, 2013 at the New Munich Trade Fair Centre in Munich, Germany.
Additionally, Gen3 Systems’ CM22 Contaminometer Cleanliness Tester will be fully operational in the “Cleaning and Contamination Testing Center” in Hall A2, Stand 429 during the four-day event. The center will provide practical support to visitors keen to implement new cleaning and contamination monitoring processes as well as overcome reliability failures.
The Gensonic Stencil Cleaning system will be displayed with a 24" stencil frame. The system uses a 40kHz on-contact ultrasonic transducer for high efficiency cleaning of stencil apertures.
The Gensonic can be used either in conjunction with Gen3 stencil cleaning centres or is portable enough to be taken directly to the printer.
The MUST System 3 is the latest technological evolution of the original Multicore Universal Solderability Tester (MUST) that grandfathered all modern solderability test standards. It remains the unquestioned industry benchmark for solderability testing. Capable of measuring down to 0.001mN the MUST is the most accurate and comprehensively equipped test system of its type in the world.
The CM11+ Contaminometer Cleanliness Tester is designed to avoid polarization effects between electrodes as might occur when using DC test currents. The CM Series utilizes a solid gold measuring cell, ballistic amplifier and a vigorous pumping system to achieve superior measurement accuracy of <0.005mS/cm even at very low conductivity values.
The Z-CHECK 3D is a non-contact solder paste precision measuring system; automatic and manual with laser options. The entire range of bench top non-contact measuring systems has been designed to provide accurate pad specific measurement of solder paste deposits, adhesives and component placement.  Each Z-Check machine comes with a full SPC package as standard.
The Solder-Saver offers companies that use wave soldering the opportunity to instantly recycle dross created in the wave solder pot, thereby saving up to 50 percent in new solder bar purchases. It can be used with leaded, lead-free or unleaded wave soldering machines
Delta T Wizard Thermal Profiling comprises a 5-channel temperature logger and user-friendly software, providing the simplest and most basic data to the most comprehensive SPC demands as the user desires.
The following Gen3 Systems’ principals also will exhibit at the event:
  • Optilia - Hall A2, Booth 166
  • MBTech - Hall A4, Booth 405
  • Finetech - Hall A4, Booth 281
  • DIMA - Hall A2, Booth 459
  • MEK - Hall A2, Booth 403
For more information about Gen3 Systems, stop by Hall A4, Stand 470 during productronica or visit www.gen3systems.com.
Gen3 Systems is a specialist manufacturer of test and measurement equipment used to help predict reliability of electronic circuits and systems in the field. In addition, the company designs and manufactures dip and spray coating process equipment in both in-line and bench-top formats. Following its acquisition of Process Support Products in 2008, Gen3 has become a specialist distributor for several leading equipment manufacturers including, most recently, Global Distribution rights for Aprotec Instrumentation, Solder Paste Inspection (SPI) systems.
Gen3 Systems also provides training, equipment and expertise for manufacturers requiring assessment of their electronic products’ reliability. The company also operates a test service and assists with standards development via both the IPC and IEC. Gen3 Systems operates from premises near Farnborough Business Park, on the M3 corridor and just 30 minutes from London’s Heathrow Airport.
Jun 17, 2024 -
May 13, 2024 -
GEN3's Graham Naisbitt Speaks with Nolan Johnson on the Crucial Topic of Objective Evidence and the New IPC J-STD-001 Standard
Mar 11, 2024 -
GEN3 to Demo SIR Testing, Stencil Cleaning & More with Horizon Sales at APEX
Feb 05, 2024 -
GEN3 to Showcase Advanced Inspection and Testing Solutions at the Southern Manufacturing & Electronics Expo
Jan 15, 2024 -
Gen3 to Release Next Generation CM Series Contaminometer in Q1 2024
Oct 09, 2023 -
Gen3 Appoints John Barraclough as Head of Business Development Following Retirement of Nick Redgrave-Plumb
Sep 04, 2023 -
Gen3 to Showcase Cutting-Edge Test Solutions at Productronica India 2023
Sep 04, 2023 -
Gen3 to Exhibit at the 24th European Microelectronics & Packaging Conference
Aug 21, 2023 -
Unlock the Future of Electronics Manufacturing: Gen3 and Zestron Workshop
Jun 19, 2023 -
Gen3 Welcomes Daniel Ryland as New Area Technical Manager for the Southern Region
53 more news from Gen3 Systems »
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Gen3 Systems to Exhibit with Stannol at productronica news release has been viewed 1236 times
