  • Gen3 Systems will present the NEW, Award-Winning CM Series and AutoSIR/CAF 2 test systems at IPC APEX 2017
Jan 09, 2017
Gen3 Systems Limited, a specialist British manufacturer and distributor, will exhibit in Booth #3136 with Ascentech, LLC at the 2017 IPC APEX EXPO, scheduled to take place Feb. 14-16, 2017 at the San Diego Convention Center in California. Gen3 and Ascentech will demonstrate the new CM+ Series and AutoSIR 2/AutoCAF 2.
The 6-Sigma, award-winning ionic contamination test systems CM+ Series will be on display.
The CM+ Series are the world’s only combined ROSE and PICT Ionic Contamination Test System.
The CM+ Series features include:
  • Complete testing within only 3 minutes
  • The entire tank volume is re-circulated 6 times every minute (CM33L up to 240 litres per minute)
  • Unique solid gold measuring cell, ballistic amplifier providing a test accuracy of <0.005mS/cm
  • Unique CURVE-FITTING Analysis algorithm (Merit of Fit)
  • Full regeneration in typically < 6 minutes
  • Smooth bubble-free circulation at all times
  • Accurate measurement even when the proportion of test solution to surface area under test are huge
  • Automatic temperature compensation
  • Measures in accordance with all international and MIL specifications old and new
  • New range of PCB/Component handling frames, with integrated draining system.
The Contaminometer series from Gen3 Systems come in 6 different models and 6 different tank sizes - when selecting a Test System, for optimum results, it is important to use the smallest possible tank size for the circuit under test. The CM+ Series comprise: CM11+, CM22+, CM33+, CM33L+, CM60 and CMBBT.
Also on the booth will be the Award Winning AutoSIR 2 / AutoCAF 2 Insulation Resistance Testers.
The key features of both the NEW AutoSIR2 and AutoCAF2 Measurement systems provide the following product enhancements:
  • Measurement Time: 256 Channels <8 seconds
  • Applied Voltage: +1V to +500V
  • CLR1000 extends the test voltage to 1000V
  • Measurement Range: 106 ω to 1014 ω
  • Measurement Method: Continuous on all selected tests
  • Measurement Test Intervals: Fully selectable from minimum of one minute
  • Capable of testing to all existing test specifications IPC - IEC - JNC and other user specifications
Both the AutoSIR2 and AutoCAF2 Systems are available with 64, 128 or 256 channel configurations.
Gen3 Systems also will give a joint presentation with Robert Bosch on the subject of Process Ionic Contamination Testing achieving 6-Sigma verification.
Gen3 Systems’ new Chief Technology Officer, Dr Chris Hunt will present as all, and will discuss verification testing for the new IPC-B-53 Test Coupon for the next revision of the SIR Test Method.
Gen3 Systems Limited is a specialist British manufacturer and distributor of test and measurement equipment used to predict reliability and maintain quality in the production of electronic circuits. We are a small team of experts offering not only equipment and test services but also full customer training and consultancy services in specialist areas.
Gen3 Systems works closely with the world-renowned UK National Physical Laboratory (NPL) that helps with the development of new measurement techniques and equipment. We are engaged in international standards development through the BSi, IEC and IPC. Our combined knowledge and experience is also employed to provide training and advice to customers, along with a range of comprehensive in-house services for solderability, SIR and cleanliness testing. For more information about Gen3 Systems, visit www.gen3systems.com.
Jun 17, 2024 -
May 13, 2024 -
GEN3's Graham Naisbitt Speaks with Nolan Johnson on the Crucial Topic of Objective Evidence and the New IPC J-STD-001 Standard
Mar 11, 2024 -
GEN3 to Demo SIR Testing, Stencil Cleaning & More with Horizon Sales at APEX
Feb 05, 2024 -
GEN3 to Showcase Advanced Inspection and Testing Solutions at the Southern Manufacturing & Electronics Expo
Jan 15, 2024 -
Gen3 to Release Next Generation CM Series Contaminometer in Q1 2024
Oct 09, 2023 -
Gen3 Appoints John Barraclough as Head of Business Development Following Retirement of Nick Redgrave-Plumb
Sep 04, 2023 -
Gen3 to Showcase Cutting-Edge Test Solutions at Productronica India 2023
Sep 04, 2023 -
Gen3 to Exhibit at the 24th European Microelectronics & Packaging Conference
Aug 21, 2023 -
Unlock the Future of Electronics Manufacturing: Gen3 and Zestron Workshop
Jun 19, 2023 -
Gen3 Welcomes Daniel Ryland as New Area Technical Manager for the Southern Region
53 more news from Gen3 Systems »
Jun 18, 2024 -
Pioneering Ultra Low Temp Li-polymer Battery for Extreme Environments
Jun 17, 2024 -
Jun 17, 2024 -
Naprotek to Exhibit at IMS 2024 in Washington, D.C.
Jun 17, 2024 -
Altus Introduces Robotic Conformal Coating/Dispensing System to Enhance Manufacturing Efficiency
Jun 17, 2024 -
Semi-Kinetics Boosts Production Capacity with Installation of Eighth Hanwha Techwin SMD Placer
Jun 17, 2024 -
Beifu Electronic Increases Efficiency with Europlacer Pick-and-place Technology
Jun 17, 2024 -
Angel Deluna Celebrates 25 Years at Circuit Technology Training Inc.
Jun 17, 2024 -
Silicon Mountain Offers Conformal Coating Services for Enhanced PCB Protection
Jun 17, 2024 -
SASinno Americas Installs Ant-i2 Selective Soldering Machine at Lonestar EMS, dba Circuitronics
Jun 17, 2024 -
CalcuQuote enhances StockCQ to empower electronics excess market with expanded access and partner-enhanced efficiency
Gen3 Systems will present the NEW, Award-Winning CM Series and AutoSIR/CAF 2 test systems at IPC APEX 2017 news release has been viewed 1064 times
