  • Nathan Trotter Introduces NT100Ge Alloy as Replacement for SN100C®
Mar 21, 2019
Nathan Trotter announces that they have introduced a new line of solder products, NT100Ge, which they will offer as a replacement for SN100C® now that the related patent has expired.
Produced using the same chemical composition as the solder alloy marketed as SN100C® by Nihon Superior Sha Co., Ltd. and its licensees, NT100Ge is a high-quality, low-cost alternative to silver-bearing solder. The eutectic tin-copper-nickel alloy creates a shiny, smooth, robust interconnect for a wide range of electronics assembly requirements. With a melting temperature of 441°F, NT100Ge is compatible with all wave and selective solder equipment. Similar to the effect of phosphorous in Sn63 alloys, the small addition of Germanium in NT100Ge serves as a de-oxidant, which keeps drossing to a minimum. For PCB fabrication applications such as the hot air solder leveling (HASL) process during which copper levels increase, NT100GeX provides a low-copper solder solution. NT100Ge can be used as a drop-in replacement for any existing 99C or SN100C® solder bath, without the need for pot dumps or swaps.
Once NT100Ge is in use, Nathan Trotter offers free, unlimited solder analysis to help maintain J-STD specifications and an optimal soldering process. NT100Ge is available as extruded 1 kg tri-bar, 7 lb. feeder bar, and solid wire on spools.
As the largest importer of tin in North America, Nathan Trotter offers industry-best pricing and flexible purchasing programs. Nathan Trotter also offers a leading-edge solder recycling program through its reclaim division, Tin Technology and Refining (www.tintech.com), which provides customers with maximum value for their solder scrap including dross and oxide, pot dumpings, paste and solder debris. Reclaim material can be exchanged for new solder or payment, enabling customers to reduce raw material costs in an environmentally responsible way.
The Technical Data Sheet for NT100Ge can be found here: http://nathantrotter.com/app/uploads/2019/03/NT100Ge-Solder-Bar-and-Wire-Data-Sheet.pdf
In the US and Canada, inquiries can be directed to E-tronix – sales@e-tronix.com - 612-803-2619 In Mexico, inquiries can be directed to ROCKA Solutions – Rodrigo Cacho – rodrigo.cacho@rockasolutions.com - +15146029449 Founded in 1789, Nathan Trotter has grown to become the largest tin manufacturer in North America. ISO 9001 certified since 1997, Nathan Trotter currently serves the Automotive, Aerospace, Electronics, Plating, and Chemical industries globally. Please visit www.nathantrotter.com for more information.
Feb 12, 2021 -
Nathan Trotter streamlines solder manufacturing with new solder bar & wire extrusion press
Nov 13, 2019 -
Nathan Trotter wins Global Technology Award for NT100Ge Solder Bar & Wire
Oct 26, 2019 -
Nathan Trotter Receives a Mexico Technology Award for NT100Ge Solder Bar & Wire
May 02, 2019 -
Nathan Trotter Expands with New Solder Production Facility
Nov 16, 2018 -
Nathan Trotter Wins Mexico Technology Award for SAC 305 Solder Bar
Oct 17, 2018 -
Nathan Trotter’s SAC 305 Solder Bar Receives Global Technology Award
Nathan Trotter Introduces NT100Ge Alloy as Replacement for SN100C® news release has been viewed 713 times
