Transducer
Jun 03, 2021
Pressure Transducer
Pressure transducers, when connected to an appropriate electrical source and exposed to a pressure source, will produce an electrical output signal (voltage, current, or frequency) proportional to the pressure. Most transducers are designed to produce output that is linear with the applied pressure and independent of other system variables — the most important of these being temperatures. Most outputs are mV, V, mA, and, sometimes, as a frequency.
Pressure transducers have a sensing element of the constant area and respond to force applied to this area by the fluid pressure. This force deflects a diaphragm, bellows, or Bourdon tube. In turn, these deflections, strains, or tensions are converted to electrical outputs through a variety of different transduction methods. Figures illustrate three of them.
To operate, most pressure transducers require an electrical input (usually called excitation). Many operate from a 5- to 10-Vdc input and produce full-scale outputs from, say, 0 to 20 mV and 0 to 100 mV. Transducers that produce high-level voltage outputs operate from voltage sources. Typical outputs are 0 to 5, 1 to 5, 1 to 6, and 1 to 11 Vdc. Digital control circuits can be interfaced by routing transducer output through an analog-to-digital (A/D) converter or by using a transducer with frequency output. This allows pressure to be monitored by microprocessors, programmable controllers, computers, and similar electronic instruments.
Pressure transducers that generate a current output usually are called transmitters. By definition, they are variable-current devices and produce 4- to 20-mA outputs with supplies of widely varying voltage.
Outputs are chosen with the following factors in mind:
  • the type of device that will receive the transducer's output signal (programmable controller, panel meter, signal conditioner, etc.)
  • the distance between the transducer and its receiving device
  • presence of electromagnetic interference (EMI) in the environment, which can come from sources such as power lines, welding equipment, solenoid valves, motors, 2-way radios, etc., and
  • cost as it relates to the entire installed system (not just the transducer).
Pressure Transducer is available through Quick Time Engineering Inc.
Jun 04, 2021 -
Vibration Monitoring
Jun 04, 2021 -
Valves, Fittings & Tubbing
Jun 03, 2021 -
Valve Controllers
Jun 03, 2021 -
Turbine Parts
Jun 03, 2021 -
Transmitter
Jun 03, 2021 -
Thermostat
Jun 03, 2021 -
Thermocouple
Jun 02, 2021 -
Solenoid Valve
Jun 02, 2021 -
Soft Starter
Jun 02, 2021 -
Smoke Detector
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
Transducer news release has been viewed 702 times
