Transmitter
Jun 03, 2021
Pressure Transmitter
A transmitter is a device that converts the electrical signal from the transducer into a much larger electrical signal that can be sent over a long distance to a PLC or a DCS. The transmitter output signal is usually a range of voltage (1 to 5V) or current (4 to 20mA) which represents 0 to 100% of the sensed physical variable.
A pressure transmitter is an instrument connected to a Pressure Transducer. The output of a pressure transmitter is an analog electrical voltage or a current signal representing 0 to 100% of the pressure range sensed by the transducer.
The pressure transmitter can measure absolute, gauge, or differential pressures. Absolute pressure is referenced to a perfect vacuum which is considered 0 psi. Atmospheric pressure is usually about 14.7psi.
The pressure transmitter will send a current signal to the PLC which represents the process pressure. The pressure transmitter is calibrated to provide a current range of 4 to 20 mA for a process pressure range of 0 to 350 psi.
Pressure transmitter is available through Quick Time Engineering Inc.
Temperature Transmitter
A temperature transmitter is an electrical instrument that interfaces a temperature sensor for example a thermocouple, RTD, or thermistor sensor to a measurement or control device like a PLC, DCS, PC, loop controller, data logger, display, recorder, etc.
Typically, temperature transmitters isolate, amplify, filter noise, linearize, and convert the input signal from the sensor then send or transmit a standardized output signal to the control device. Common electrical output signals used in manufacturing plants are 4-20mA or 0-10V DC ranges. For example, 4mA could represent 0°C and 20mA means 100°C.
Temperature Transmitter is available through Quick Time Engineering Inc.
Jun 04, 2021 -
Vibration Monitoring
Jun 04, 2021 -
Valves, Fittings & Tubbing
Jun 03, 2021 -
Valve Controllers
Jun 03, 2021 -
Turbine Parts
Jun 03, 2021 -
Transducer
Jun 03, 2021 -
Thermostat
Jun 03, 2021 -
Thermocouple
Jun 02, 2021 -
Solenoid Valve
Jun 02, 2021 -
Soft Starter
Jun 02, 2021 -
Smoke Detector
May 23, 2024 -
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
Transmitter news release has been viewed 662 times
Benchtop Fluid Dispenser
