  • New Yorker Electronics Releases Supercapacitor with High Voltage and High Energy Density
Dec 23, 2020
New Yorker Electronics to Supply new Cornell Dubilier Electronics (CDE) High Voltage Supercapacitors
Cornell Dubilier 3- and 6-volt Capacitors Offer Greater Power and Energy Density than Typical 2.7Vdc Parts
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced the release of the new Cornell Dubilier DSF Series of high voltage and high energy density supercapacitors. The DSF Supercapacitors also provides greater power density, extremely low self-discharge rate, low ESR and ultra-fast charging. Applications for this new device include green energy, backup power, industrial internet of things (IIoT) and small electric vehicles.
Being released under the Illinois Capacitor brand, DSF Supercapacitors offer a notable jump in voltage rating over typical supercapacitors, to 3.0 WVDC for a single component and 6.0 WVDC for a dual-pack device. This higher voltage spec results in greater energy densities, which in turn saves space and may reduce the number of devices required.
The DSF Series includes 17 different value/voltage combinations, ranging in capacitance from 1.5F (Farad) to 600F, with voltage ratings from 3.0 to 6 WVDC. Multiple devices can be banked in series or parallel for even higher voltage or capacitance. ESR varies by part but is lower than most capacitors with similar storage capabilities. With an operating temperature range of -40°C to 85°C @ 2.5V (-40°C to +65°C @ 3.0V), the DSF is tolerant of wide-ranging operational environments.
Like other supercapacitors offered under the Illinois Capacitor brand, the DSF Series gives engineers increased design options while holding down costs. With increased energy storage, supercapacitors can provide instantaneous bursts of power that cannot be matched by conventional capacitors. That capacity makes it possible to smooth brief power interruptions, supplement batteries, or even be used in place of batteries in certain applications. Unlike batteries, DSF supercapacitors do not degrade with each cycle and are rated at 500,000 cycles. Operating life is expected to be up to 10 years.
Specific applications for DSF supercapacitors include: solar and wind energy harvesting, mechanical actuators, AGV (Automated Guided Vehicles), EV transportation power, smart utility meters, pulse battery pack alternatives, memory backup, battery/capacitor hybrids, UPS systems, emergency lighting, LED power, solar lighting or anywhere that significant energy storage is needed.
Depending on voltage and capacitance, there are four-lead configurations available. These are radial, two-pin snap-in, four-pin snap-in, and radial dual pack. Case diameters and configurations vary. Custom modules, with active or passive balancing, are also available, to meet higher voltage or capacitance requirements.
Features & Benefits:
  • High Voltage
  • Very Fast Charge/Discharge
  • High Power Density
  • Lower ESR
  • RoHS Compliant
Applications:
  • Battery Backup/Alternative
  • Pulse Power
  • Energy Harvesting
  • LED Displays
  • Mechanical Actuators
  • Audio Systems
New Yorker Electronics is a franchise distributor for Illinois Capacitor and provides its full product line of miniature capacitors for electronics, lighting, energy and other markets including aluminum electrolytic, metalized film, power film, supercapacitors (ultra capacitors), supercapacitor modules and other types.
Nov 03, 2023 -
Apr 17, 2023 -
Apr 17, 2023 -
Apr 14, 2023 -
Apr 14, 2023 -
Apr 05, 2023 -
Apr 05, 2023 -
Apr 04, 2023 -
Apr 04, 2023 -
Apr 03, 2023 -
Sep 07, 2024 -
FOXBORO FBM207B Channell Solated P0914WH
Sep 07, 2024 -
FOXBORO FBM228 P0922QS COMMUNICATION FIELDBUS MODULE
Sep 07, 2024 -
FOXBORO P0931RQ Cable
Sep 07, 2024 -
FOXBORO FBM215 CHANNEL ISOLATED 8 COMMUNICATION HART OUTPUT
Sep 07, 2024 -
FOXBORO CP40 Model
Sep 07, 2024 -
FOXBORO FBM230 P0926GU
Sep 07, 2024 -
FOXBORO P0916VC
Sep 07, 2024 -
FOXBORO AD916AG
Sep 07, 2024 -
FOXBORO P0904BS P0904BS-0E
Sep 07, 2024 -
FOXBORO PO177VS
New Yorker Electronics Releases Supercapacitor with High Voltage and High Energy Density news release has been viewed 572 times
