  • Squeegee Cleaning Machine HJS-4300,ink, glue liquid screen squeegee automatic cleaning machine for screen printer
May 11, 2022
Cleaning   Objects:Ink,silver   Paste, Glue Squeegee
Squeegee Length:900mm
Squeegee   Numbers:6pcs
Liquid Tank   Capacity:80L
Water Tank   Capacity:80L
Liquid Temp:RT~60℃
Water Temp:RT~60℃
Rotation Speed:10~15 RPM
Ultrasonic:40KHz
Spray Pressure:4~5kg/cm2
Power Supply:AC380V. 3P,50/60Hz,   28KW
Air Supply:0.5~0.7Mpa,   200~400L/Min
Machine Size:L1700*W1300*H1300mm
Machine Weight:500kg
High Light:80L screen   cleaning machine, 40KHz screen cleaning machine, 40KHz Automatic Screen   Cleaning Machine
Product Description:
HJS-4300 ink, glue liquid screen squeegee automatic cleaning machine for screen printer. It is an off-line, compact, energy-saving, batch cleaning, screen squeegee cleaning machine. all kinds of screen printing material inks, silver paste, glue... can be throughly cleaned by HJS-4300. It is an automatic running machine; wash, rinse, dry process in one chamber by just push" start" key. Inks residual was kept in filter barrel and cleaning tank.
Machine Features:
1.      Special designed to clean printing ink, silver paste,glue...etc on screen squeegees .
2.      Ultrasonic and spray clean at the same time to clean all the leftovers off from the squeegees.
3.      Clean, rinse, dry process, thoroughly clean, standby and ready to use at any time.
4.      6 squeegee racks: can clean 4 pcs of 900mm squeegees in one time.
5.      State of the process is visible through a large observation window.
6.      Clean liquid heat system heat liquid to a certain temp, raise clean efficiency and reduce clean time.
7.      Easy operation interface, quick setting clean parameters. Different passwords can be set.
8.     Inner filter makes liquid used repeated. .
9.     Totally SUS304 structure, very firm and attractive.
Q1: How many squeegees can HJS-4300 clean at one time?
A1: 900mm length squeegees, 6 pcs; 400mm length squeegees, 12 pcs.
Q2: How HJS-4300 can complex squeegees clean?
A2: HJS-4300 use ultrasonic cleaning and spray cleaning technology.
Q3: What is cycle time of HJS-4300?
A3: about 20 minutes.
Machine links:
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Squeegee Cleaning Machine HJS-4300,ink, glue liquid screen squeegee automatic cleaning machine for screen printer news release has been viewed 539 times
