  • Semiconductor Spray Cleaning Machine HJS-9600, leadframe, IGBT, IPM, BGA, CSP package flux clean
Jun 07, 2022
Semiconductor Spray Cleaning Machine HJS-9600 , leadframe, IGBT, IPM, BGA, CSP package flux clean
Product Description
HJS-9600 is a compact in line spray cleaning machine for leadframe, IGBT, IPM, BGA, CSP package flux clean by using liquid wash and DI water rinse and hot air dry.
For all kinds of flux and leadframe, IGBT, IPM,BGA, CSP package.
HJS-9600 working process: Pre-wash+Wash+ Chemical isolation+ Pre-rinse+ Rinse+Final rinse+ Air blow dry+ Hot air dry1+ Hot air dry2.
By using HJS latest mix spray cleaning technology, the system has following advantages:
1. Leadframe package flux in line cleaning system.
2. Liquid mix spray wash technology, super wash result, thoroughly clean water-sular solder paste flux and non-clean flux.
3. Longer wash sections + DI water rinse section+ Air blow section +2 hot air dry sections.
6. Liquid and DI water spray pressure can be adjusted for different semiconductor products cleaning requirements.
Machine Spec:
S/N
Item
HJS-9600 Spec
conveyor net
600mm
2
conveyor speed
0.1~1.5m/min
3
conveyor height
900±50mm
4
conveyor direction
Left to Right
5
product size
L400*W600mm as max
6
product height
100mm as max(with component)
7
wash tank capacity
120L
8
rinse tank capacity
30L+60L+30L
9
DI water consumption
400~800L/H
10
exhausted air
36m³
11
electric control
PLC+TP
12
Resistivity range
0~18MΩ
13
PH range
0~14
14
air supply
0.5Mpa
15
power supply
AC380V,50/60HZ, 3P,110KW
16
machine size
L5200*W1750*H1650mm
17
machine weight
3000KG
Customer Question & Answer
Q1: What kind of semiconductor products can HJS-9600 clean?
A1: Flux on BGA, CSP, IGBT, IPM Leadframe package. it has 600mm wash section with 2x8 spray rods on it, that's why it is so powerful.
Q2: Why is it 110KW?
A2: in wash section, it has 3x12KW heater; in pre-rinse section,it has 1x12KW heater; in Rinse section, it has 1x12KW heater; in hot air dry section ,it has 2x7.5KW heater, and we also have air blowers, electric pumps.
A4: It depends on liquid itself and temperature, we install liquid cool condenser, normally 5~10L/ Hour.
SIP package picture
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Semiconductor Spray Cleaning Machine HJS-9600, leadframe, IGBT, IPM, BGA, CSP package flux clean news release has been viewed 436 times
