  • Camera Lens Cleaning Machine HJS-9800,semi conductor Camera Lens Cleaning Machine
Jun 12, 2022
Product Description
HJS-9800 (Camera Lens/ Micro Dusts Semiconductor/ Cleaning Machine/ Di Water 2-Fluid Spray Cleaning Machine) is mainly used to clean micro dusts on camera module products such as: Wafer, CMOS, Holder...etc. By using our DI water scan spray cleaning technology, HJS-9800 wash out very little micro dusts and by using 1000RPM centrifugal dry technology, HJS-9800 can quickly make products dry.
Machine Features:
1.   Specially designed to clean dusts on camera module products.
2.   Mirror stainless steel structure, suitable for clean room.
3.   Clean plate is specially made according to products, clean plate can be changed according to different products cleaning requirement.
4.   PLC control, easy operation.
5.   Transparent explosion-proof front door, safe operation, convenient for observation.
6.   All machine displayed by meters. Cleaning status are monitoring at the time.
7.   2 stream clean, high cleaning precise, no damage to products, very few DI water consumption.
8.   Rotate spray rods, no secondary pollution.
9.   Equipped with static eliminator, cleaning room heat device, help to achieve best cleaning result.
10. Equipped with 2-level air filtration system, compressed air meets the standard of ISO8573.1.
11. Compact machine, smaller foot-print.
12. Use pure DI water, comply with RoHs standard.
Machine Spec:
Cleaning Plate
Custom-made (cleaning plate diameter<550mm)
Clean method
2 stream clean
Dry method
High speed centrifugal dry
Power supply
AC380V 50HZ
Power
7KW
Power consumption
Cleaning power: 3.5kw/h
Standby power: 1kw/h
Rotate power
3HP
Environment filtration method
0.3μm;99.999%
Air filtration method
1μm×1;0.01μm×1
Centrifugal rotating speed
100-1500RPM
Clean pressure
Water   pressure:3-8Kgf/cm²     air pressure:0.2-0.5Mpa
DI water supply
Flow rate:>7LPM  Resistivity:>17Mω
Air consumption
Pressure:0.45-0.7Mpa; flow   rate:>30m³/H(good cleanness)
DI water let in diameter
ø12mm soft hose or PT1/2′ female joint
Air supply diameter
ø12mm hose
Water exit diameter
PT 1′female joint
Air exit diameter
4′×2(need air-pumping device, air speed over   3m/sec)
Machine size
880mm(L)×960mm(W)×1880mm(H)
Machine weight
450KG
Machine picture:
Dec 14, 2022 -
Dec 08, 2022 -
Dec 06, 2022 -
Dec 01, 2022 -
Nov 30, 2022 -
Nov 23, 2022 -
Nov 22, 2022 -
Nov 21, 2022 -
Nov 18, 2022 -
Nov 17, 2022 -
Camera Lens Cleaning Machine HJS-9800,semi conductor Camera Lens Cleaning Machine news release has been viewed 440 times
