  • What is the reflow soldering process requirement for PCBA processing?
May 20, 2023
At present, reflow soldering technology in SMT chip processing has been widely used in the field of electronic manufacturing. All electronic products, industrial, medical, communication, and other circuit boards used in our lives, and chip processing components are all through this reflow soldering process. soldered to the PCB board. The advantage of this process is that the temperature setting of each temperature zone is easy to control. After the placement is completed, it can be passed through the furnace in time to avoid oxidation through the same track of the wire body. If it is a double track, different PCBAs can be reflow soldered at the same time, and the manufacturing cost is also easier to control and reduce. The principle of this kind of equipment is to control the heat generated through the internal circuit of the equipment through the temperature we set. After the nitrogen gas is heated to the set temperature, the upper and lower hot air rolling cycles are used to heat the PCB and the components evenly, and the solder paste reaches a certain melting point (lead-free 217 degrees Celsius) to realize the soldering of the component pins and the PCB pads, and then solidify.
The curve of the solder paste
In combination with the temperature curve provided by the solder paste manufacturer, reasonably set the actual chip processing PCB board reflow soldering temperature curve and conduct real-time testing of the temperature curve regularly.
PCB design
Welding should be carried out according to the welding direction of PCB design, including comprehensive factors such as circuit board material, thickness, grounding area, PCB board size, component size, and heat absorption
The vibration of the reflow oven
Strictly prevent the vibration of the conveyor belt during the reflow soldering process, and monitor and maintain the equipment in real time.
Inspection
The welding effect of the printed board must be checked. Cold soldering (cold sweat is now called insufficient melting of solder paste) is difficult to judge with the naked eye, resulting in poor circuit connection performance.
Others
Check whether the surface of the solder joint is glossy, whether the shape of the solder joint is semi-crawling, and whether there are solder balls and residues around the solder joint, short circuits, and false soldering. In particular, check the color change on the surface of the PCB. If there is discoloration, it means that the temperature setting of the PCBA board for the current patch processing is too high. And adjust the reasonable temperature curve according to the inspection results. It is necessary to inspect the welding quality at the back end of the reflow furnace from time to time to avoid batch welding problems and reduce unnecessary losses.
Summary of reflow soldering process requirement of SMT
The above content is shared by SZTech-SMT for you on the principle of SMT chip reflow soldering. I hope it will be helpful to you. To learn more about SMT chip processing, welcome to visit www.sztech-smt.com
Jul 10, 2023 -
How to maintain SMT machine?
Jul 10, 2023 -
How to inspect BGA solder joints in SMT processing?
Jul 10, 2023 -
What is the principle of AOI inspection?
Jul 10, 2023 -
What is the precaution for the SMT production process?
Jun 01, 2023 -
Precautions for SMT production line
May 20, 2023 -
What is the SMT process flow? Check SMT process introduction
May 20, 2023 -
How does SMT solder paste affect soldering quality?
May 20, 2023 -
What is the core machine of the SMT processing plant?
May 20, 2023 -
How to effectively store and use solder paste in an SMT patch processing factory?
May 20, 2023 -
What is the working principle of SMT reflow soldering?
14 more news from SZTech-SMT Firm »
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
What is the reflow soldering process requirement for PCBA processing? news release has been viewed 913 times
